It's not the equalizer as I guess it is called, there is no button on it, I took the hose off the left front brake and there was no fluid except a few drops, I pumped the brake a few times to see what happens and it makes a girgiling noise abd only a few drops come out. Same if I disconnect the lines from the master cylinder(new and old one) same thing, it just drips out. The master cylinder does not lose any fluid when pumped, only a few drops. As this is with both the new and old one, same result.
Could this be a bad booster behind the master cylinder?
Thanks.
EDIT: Did'nt find what was wrong, but after about 2 mins of pumping the brake pedal, fluid start squirting out of the master cylinder so I hooked everything back up and sure enough fluid comes out the broke hoses now. Got everything hooked up, and when i went to bleed the drivers caliper, I discovered the broken bleeder nipplie. The previous owner had ripped off the end of it, I guess from over torquing everything. He(or she) even managed to strip the head off of the caliper bolt and now I cant even get the bolt out with all my weight on it. Had to take the whole caliper off and order a replacement. $124. mad as hell at the moment.
