A Half Crippled Old SOB....
I'm using this column in a project & I need a wiring diagram for the wiring in the steering column for a 93 Buick Park Ave. Mainly the turn signal, hazzard, wiper & cruz stuff.....thanks..joe
Doc here, :pimp:
All I have is info on a 93 Le sabre, Which should be CLOSE to the park ave, BUT Continuity check with an Ohm meter to verify Color and function are correct..It may differ...
Windshield Wipers
  • WHT = Power, Fuse #5
  • GRAY = W/W Fluid washer AND Gray on WW motor.
  • PINK = Motor Speed Control.
  • GREEN = Motor speed control.
  • PURPLE = Motor Speed Control.
BEAM SELECT SWITCH
  • LT BLUE = High beam
  • TAN = Low Beam
  • YELLOW = Head Lamp Switch.
  • BLACK = Head lamp Switch.
TURN SIGNAL SWITCH
  • PURPLE = Flasher
  • GREEN = R/Rear Directional signal.
  • WHITE= Lamp Module AND Brake lamp switch.
  • YELLOW= L/Rear Directional Signal.
  • BLUE = Lamp Module AND Pin A2 of Instrument Cluster.
  • LT BLUE= Lamp Module AND Pin A6 Of Instrument Cluster.
  • BROWN=Haz Flasher.
GEAR SELECT SWITCH.
  • LT ORANGE=Backup Lamps
  • YELLOW=Starter energize relay.
  • PINK/BLACK=Power,Fuse#2
  • BLK/WHT= Ground
  • PURPLE=Starter Solenoid.
  • BLK/WHT=Pin 8 of ECM.
Again, This pertains to a 93 Le Sabre..IT MAY differ, so check Color Vs Function with an Ohm meter first, But it Should be the same or very close.
Hope it helps!
Doc :pimp:
Discussion Starter #3
Thanks Doc, I was hoping you'd show up w/some info, since it seems you are "da'man" when it come to the electric stuff in cars... thanks again ...joe
Doc here, :pimp:
Thanks!
Let me know if the Color Vs Function is correct for your Column, If not I'll try to research an exact one for it.but I think it should be the same.
Doc :pimp:
