bad spelling day
cusz28 said:
it has provisions for all the roller stuff, even the lifter bores are cut for dogbones and threads for the spider, but it has flat lifters and cam. it's as simple as remove needed stuff from lt1, and swap it into my tbi. everything's ready.
The LT1 cam, even as mild as it is, constitutes a big timing increase compared to the truck cam. It will show more power and wont' be so insane that the TBI Swirl Port heads will be much of a detriment unless you intend to run above 4500 RPM regularly. The LT1 is rated at 300 hp at 5000 RPM which isn't far away from the Swirl Pots typical flop over at 4500 revs. This cam also is rated at 340 pound ft of torque at 4000 RPM which is a lot more than your truck engine delivers and again is inside the flow capacity of the swirl ports. The problem you'll have is giving up compression; the LT1 has a static compression of 10.4, the swirl port heads bolted over GM's deep dish truck pistons probably never squeezed more than 8.5 on their best day. So you're not going to get LT1 numbers, but you will get a noticeable improvement. I'd hazard an educated guess that with the Swirl Port heads you're looking at 260 horses and 290 pound feet of torque, that's compared to your existing engine which has been rated around 190 (Calif) to 207 (49 state) hp with about 275 pound ft of torque.
The rub is the computer and sensors that make TBI go, while the LT1 cam is not a lot different from the Edlebrock 3702 which is supposed to be usable with TBI engines without a new chip, the LT 1 has a bit more duration and lift. 194/.378" and 214/.442" for the 3702 and 205/.447 and 207/.459" both cams with a 1.5:1 rocker for lift at the valve measurement. The Edlebrock runs a 110 degree LSA and the LT1 is 115 and it's ground 1 degree retarded. The issue here is not so much the timing differences against the milk toast truck cam which is about 160 degrees with a lift around .34 inch, but is the effect these other cams have on the ratio of throttle position to Manifold Absolute Pressure (MAP) which you can think of in rough terms as manifold vacuum, and RPMs. As cam timing changes, the ratios of throttle opening to manifold vacuum, to RPMs also changes. As these are the three major functions the computer looks at to find the fuel and ignition timing requirements on a table; when these aren't what the chip is programmed to see, the integration of these values has the computer looking in the wrong place on the lookup tables. A new chip, for which there's a lot of places that make them out there on the web, becomes required to put the ratios back into alignment with the fuel and ignition maps. Chips run around 3-400 dollars.
The LT cam fits your engine with the removal of a pin on its nose used to drive the distributor and water pump mechanism of the LT1/4. This will, also, require the use of the roller cam drive gear and chain set as there isn't space with the longer nosed cam inside the timing cover for a double row chain. Even with the GM single row roller, it may be necessary to run a couple/three gaskets under the timing cover to eliminate contact between the chain and cover. The timing set for the 1996-2002 Vortec works just fine.
If your messing with the chip, then one needs to hazard the possibility of replacing the 400 CFM TBI of the 350 with a 600 cfm unit more in keeping with the engine's new breathing potential. Then your mind gets to thinking about better heads and the budget becomes totally shot out the window. But if you're entertaining these thoughts be aware that the chip needs to reflect all these changes so you should do everything at once and rechip the computer for all of it, otherwise costs get really out of hand.
Keep in mind that GM's V8 roller cam/lifter combination uses a shorter push rod. If you don't have these with the pile of parts you got, you'll have to get a set. 90 degree V6's use a shorter lifter and close to standard length push rods. But these won't work in a V8 roller block, they, however, can be adapted to a non roller V8 block.
The bigger problem is 210 thousand miles, while the engine and transmission may be in good shape relative to their years and miles, there is no doubt that this is on the upper range of life expectancy and suping up the engine will not enhance its or the transmission's life expectancy.
