I'm curious if I can cheaply and easily duplicate the effects of an older Firebird I once had.
It had a custom four link (with panhard bar) and to this day my brother still talks about that car because of the "action".
It was setup so that when it had slicks it stayed level in the rear, but with street tires the rearend would raise up in the air.
I know I can fab something up as far as mount pads for the trailing arms...if I just knew more about geometry of the rearend.
I can also make custom trailing arms so that will not be a problem(and maybe a blessing) if all I have to do is shorten or lengthen the uppers or lowers.
-Thanks!
Ok, after reading up on this I am thinking that I can modify the lower trailing arm body mounting point to raise the lower trailing arm.
This should give that "rise" on street tires and a firm bite on slicks...or should i rasie the top mount?
-Thanks!
