I grabbed a 2wd 94 s10 that had a junk 2.2, 5 speed and then started cutting and welding. Despite everything else being modified I left the IFS (and glass) alone. The front end is perfect just how it is. The front "small" calipers will also work just fine.
Before I build custom length crossover steering it would be a good idea to replace the rusted control arms, bushings, springs, brakes and spindles.
This thing is a 94 and when I bought it the thing was being parted. The frame ended up having 9" hole right in the middle to give you an idea on what I started with. The control arms are badly rusted to the point I could pull chunks of flaked rusted metal off around 3/16" ish. So probally not a good idea to run those anymore. The spindles may be good enough to just reuse with some new bearings. Worst case I will just reuse them or some other "good" used ones from someone doing a 2" drop. But I would just rather buy some new ones.
Just start with a completly new IFS that will bolt up to whats left of the old frame. No need to complicate a system that works just for looks.
Being all stock you would think parts would be easy to find.
Speedway sells a complete new upper and lower arm assembly with all the bushings, bar, ball joints, etc installed so thats a no brainer.
I will buy it off amazon from speedway using a gift card and it will be around $200 with alot of headaches eliminated.
I am going to run new stock 4 cylinder springs and then will play around changing shocks to get the feel I want. The shocks just drop through the middle of the spring/control arm on 2wd so I won't need to remove the lower arm each time.
The thing I am running into is the sea of all the lowered aftermarket stuff for the s10 spindles. Mix in some A, B, X, G body "metric" spindles and I have a good chance of having "stock" spindles that are just different enough to cause a issue or I will flat out end up with lowered spindles.
I have been roaming G body sites thinking that might be easier to just say I have "this" give me stock spindles. They use the s10 spindles because the hole position which is around a half a inch diffrent and allows for a bit tighter turning radius.
As long as I change the spindles before welding up the drag link, and tie rod heims I can adjust for the diffrent hole position. But I would rather just use s10 spindles so I can keep the IFS all 94 s10 when replacing bearings/rotors.
I highly expect to see some scoring on the spindles I currently have. Lots of part outs of the 2nd generation s10 so I should be able to find spindles. But frankly I know I personally would not waste time tearing apart the IFS for used parts I might sell for $40.
I don't expect to find anyone selling just the spindles. Maybe a entire frame though.
Junkyard is a option I don't want to play with when it is 10 degrees out. Lots of time wasted for potentially just slightly better condition parts.
I have found 83 to 94 2wd blazer "steering knuckles" which should be the same. But everything is out of stock or $300 to $450 PER SIDE (Dorman). I am fine paying $200 even $250 after shipping for a set of spindles. Lots of "metric" ones in that price range. But $250 is the point where I can justify just running the ones I currently have.
So where can I find factory height 94 s10 spindle replacments?
