I just got a 96 camaro rs shell for free and straight body I got a I believe a 4l60 tranny with it is there a way I can use this transmission with a 350 first gen motor and. Do I need to run the controller box if I can
If it was originally a V8 car, the engine bolts up. If it was a V6 car, it won't. If it's a 4L60E (as opposed to a 4L60), it doesn't shift without a computer.I just got a 96 camaro rs shell for free and straight body I got a I believe a 4l60 tranny with it is there a way I can use this transmission with a 350 first gen motor and. Do I need to run the controller box if I can
Ok Its a v6. So ill Have to Fine a tranny do u know how much work till be to get the 350 first gen to fit in the car
I was just joking more or less about cutting the hole, but you're going to be hard-pressed to do any adjustments or tune up work with it buried under the cowl back there. Mines a pain in the butt as it is, and it's in a fullsize truck with a ton of room. Are you married to the idea of putting a gen I sbc in it? An LT1 would be cheap, a 5.3L would be cheaper. Both would avoid your distributor problem.So u have to cut a hole in dash is there any way around it
yup.. run a lt1 gen 2 or an lsSo u have to cut a hole in dash is there any way around it
My honest suggestion (Take or leave it) is to either trade the F-body for a car that will be a lot easier to swap your 350 into, or trade the 350 for an LT1 or 5.3L. You'll be harder pressed to do the latter, but crazier things have been traded in a situation where someone needs something. Craigslist will be your best friend in either instances. If you still decide to push forward on your current plans, I'd go search the forums over on LS1tech.com I'm sure a couple guys have done this swap before there and might have some tricks that will get you around your distributor issues.I probably would be ok with going le1 but ive got sbc Hwre thats already built and im short on Cash that way
