I have a 96 chevy K1500, 5.7l. The intake gasket failed and the engine filled with water/antifreeze. I actually added more before I realized the problem. I was drive to work and the engine started to run rough and actually die on me. It cooled off a little and started back and I got it home. I then tore it apart to replace the intake lower gasket. I noticed that the water/oil was all the way up into the breather. I cleaned as much of the intake and engine as I could and put it all back to gather. Now it will not start. It just cranks. I have checked the plug and am getting fire and fuel. Since it will not run I can not get any codes.
Could a sensor be blinded and not letting it start?
I moved your post to Basics Forum. Introduction forum is not for tech questions. Thx
