.. Ok here goes... 89' caddy eldorado 4.5l v8 ... ok i have a friend with a 980 i belive beretta and he hit a deer with it and i would like to convert my 4.5 to a manual transmission... from what i have found out the 2.8l trannys will bolt to the 4.5l so my question it what cluth flywheel would i use? can i make custom shift rods? what axles can i use? can i use the stock brakes and hubs? if i cannot make a mecanical cluth work is there a kit to make a hydraulic clutch fit this application?... I know its not a hot rod yet.... i also would like to know about performace things and show things like what valve covers to use or what custom airfilter will fit the tbi? also where can i get bigger injectors? or velocity stacks?... what companies offer pipe in a box for building headers for something like this? anything would help for this.. are there shiftkits available for the automatics in them... or if i put the manual in it is there much available to upgrade them?? thanks bret
