SixEightFury said:
Although i could build a Frame, i dont feel my skill knowledge is that great, so i was wondering what types of frames Could i use? could i use a normal S10 rolling frame like an 80s ETC Or would i be better off with something much older and harder to find?
i was just curious
Hi
There is a book by Tex Smith called 'How to build Hot Rod Chassis' that I found useful, there is a section in there on modifying other frames. Although it is mainly about constructing them from scratch.
If you are fairly flexible on position and types of engines, trans, suspension etc. or will be using the same engine and running gear as the frame, modifying it might be a good way to go.
But if you have particular ideas on what you are going to use and will be doing a lot of modifying don't completely discount the idea of constructing a frame. You will be using similar skills modifying a frame as building one.
