The vehicle... 1969 Chevy C10 SWB new model (1994) bed, converted to disk in front (5 lug all around)... Well built 12 bolt with Eaton locker/Richmond 4.65 gears...
The BBC... 427 cui (.030 over) has 2 bolt block very well preped with ARP studs, steel crank, fluid dampner, truck rods (bushed for full floating pins) ARP bolts in the rods, L88/ZL1 closed chamber 12.5 to 1 pistons (TRW forged)... 7 quart kick out Moroso pan with HP/HV oil pump... Performer RPM cam .573/.562 lift with 1.7 rockers and matching lifters... CP pushrods (3/8ths chrome moly) CP guide plates, Trickflow rocker studs, Cat 1.8 ratio stainless roller rockers w/locks... GM large oval port 781 casting heads with 2.19/1.88 stainles valves, Comp springs, Titainium retainers, Chrome moly 10 degree locks... Heads were bowl cut for the larger valves and gasket matched only... Performer RPM intake and will use a custom serpentine setup with March underdrive pulleys... topped off with a Barry Grant speed demon 750 (mechanical)... Also choice of either a 700R4 (well built and for racing) or a Turbo 400 with manual valve body and very good hard parts...
OR...
2002 Vortec 5.3 (New and complete basicly stock) but has cam changed to the hot cam .525/525 and also may include a 100-150 nitrous kit...? Also will have a 4l60E with LS1 converter behind it...
I have both engines and trans... but cant decided which one to use...? Should it be the old school/old school or old school/high tech...?
Opinions...?
thanks.......
OR...
Opinions...?
thanks.......
