1 - 16 of 16 Posts
Listen and Learn
Im looking for an engine management package for my new build. Its gonna be a fuel injected sbc 350, with a mild towing rv cam cr will be around 9.25:1. I have an intake from an 86 camaro i am gonna use. I have found two packages that include the computer, harness and software. One is the holley commander 950, http://www.summitracing.com/parts/HLY-950-101/
and the other is from accel, http://www.summitracing.com/parts/ACC-77010P/. anyone have experience with either and can chime in their opinion.
Premium Member
Honestly, if you're not afraid of the learning curve you can run a stock 86-89 (or 90-94 if you want to tune based on a MAP sensor) TPI computer and get the stuff to burn a chip for it. It would save you roughly 400-500 dollars. It didn't look like either system came with a wideband sensor, which would be a big appeal of an aftermarket system and justify the $1100+ price tag.
I haven't used either of those systems, but have done quite a bit of programming on a 85 TPI Corvette, and my old 66 GMC with an 89 TPI system.
you will need make your own harness but with the mega squirt you can use factory parts from a salvage yard an cut the plugs from them an form your own harness use the injectors from a donor an plugs an map sensor an plug iac an plug an so on ! just be alot soldering i'd also if like save money try get a completer harness from a donor so you have gage wire for the harness it's a complete do it yourselfer system! but about cheapest way to go! i myself not got a system yet but one i'm getting i get to that point my build!
or if up to trying put a bosch injection system thats mechanical no sensors needed but be alot fabbing! an finding an old enough bosch system anymore from a beamer V-8 or 2 VW rabbit bosch systems one to feed each side the motor!
Listen and Learn
Discussion Starter · #10 · (Edited)
I already have a harness and stock computer. Maybe i should throw them on ebay and then buy that harness and just solder and crimp all the connectors on. Can i buy the connectors new, or should i hack up the harness i have now?
Did some research and from eficonnector.com: http://www.eficonnection.com/eficonnection/tpi_pigtails.aspx
for injectors, tps, map, iac, cts, and iat would be about $120. Cant think right now what else i am forgetting.
Premium Member
Or you could go here and be cool like me :)
http://www.moates.net/
Honestly I've heard good things about a megasquirt so if thats the path you choose, its a good choice. It was just easier for me to go the custom chip route as I had the sensors, and had always wanted to learn tuning anyways.
I assembled an MS-II this weekend. It took about six hours for me to solder it together. I bought a relay board this time. I'll buy one from now on. It has a clearly labeled terminal block for attaching your harness to. I always make my harnesses but I think you could easily use your factory harness if you cut the ecm connector off. I have four cars on MS-II's. One on an MS-I. The MS-I doesn't do ignition on it's own, has smaller tables and a less powerful processor.. The only other expirience I have is tuning an AEM-EMS plug and play in a supercharged Mustang. The AEM is nice but I didn't have to pay for it. Between the DFI and the Holley, I think the DFI would be the better choice.
Kevin
Premium Member
It's actually an adapter you put into the computer, and then a flash chip onto the adapter. It comes with a programmer you plug into your comp via a USB cable, set the parameters, and burn the chip. Then you take othe other cable provided, and the software, and plug it into your car and drive/datalog and make changes as needed.
There is a bit of a learning curve to it all, but it's very rewarding in the end. I don't know if the programming of the Megasquirt or those other systems has been simplified, or if the learning curve is about the same on all of them.
Listen and Learn
Discussion Starter · #15 ·
This all seems rather simple and actually sounds like fun. When i was looking at the $1100+price tag of the other systems i was kinda worried it wouldn't be worth it. I am gonna look over the harness tomorrow and make sure all the connections are good on it and the relays are intact. Its been so long since i looked at it. Thanks for the advice on the system siggy I will let you know if i have any problems and if it turns out good. I have a test stand in my engine shed so hopefully i will have it running this winter. Prolly just run it on one of the 305s i have sitting around just to get used to tuning the computer. Thanks for all the help everyone, this forum is awesome!
Premium Member
There are already pre-done tunes you can download as well that work really well as a starting place. They'll at least be good enough to have the engine running and driving, but will probably be less than optimal performance :).
1 - 16 of 16 Posts
