1 - 8 of 8 Posts
My compressor (220 volt/5hp motor) puts out adequate air, but it is a portable unit (read small) and therefore I run the tank out pretty quickly when I use certain air tools. I'd like to plumb a second tank into the system but use quick release couplings to do it so I can still have the portability if I might need it. Anybody have a two tank system or know how I can plumb in the second unit? Can I just insert the new tank in the line between the compressor and the original tank?
Dewey
Hotrodders.com moderator
Yup
Just place the other tank inline..got the same setup tho I am thinking of getting a larger compressor as mine is way small..works fine for one guy..
Still have to stop and let the compressor catch up tho not so often..:thumbup:
Mine is set up exactly that way. I picked up a large (200 gallon) tank for cheap. I feed the line from the tank on the compressor in one end of the biggie and take my air out the other end. Everything is fitted with quick couplings. The side benefit I discovered is that it seems to keep a lot more moisture out of my lines.
I tried hooking this up yesterday and ran into a snag. The additional tank I am using is one of those portable tanks (used to fill and carry - not meant to have it's own compressor). My plumbing went from the compressor to a "T" mounted on the new portable tank and then back to the tank that the compressor is mounted on and then out through the regulator.
What happens is that when I fill the two tanks and the regulator shuts off, the "portable" tank continues to blow air back to the compressor and then the compressor sends it to the regulator mechanism where it bleeds off until the portable tank just empties out. This bleed off is apparently incorporated in the original set up to relieve the pressure in the line between the compressor and the tank and in the past, every time the compressor shuts down, there is a second or two of hissing as the air in the line is allowed to escape. When the "add-on" tank is plumbed into the system, however, the hissing just continues until the new tank is empty.
I'm thinking there must be a one-way check valve in the original tank (the one the compressor is mounted on) which prevents this from happening under normal conditions and that I need a similar check valve installed at my new add-on tank. Does anyone know for sure if this is the case?
Compressor plumbing
I just plumbed mine from the existing outlet..works fine that way,,not sure what you did..:spank:
try that and see what happens..??
Instagram: partsretriever
put a "tee" (1 in, 2 outlet manifold) right at the outlet of the main compressor/tank. One outlet goes to the second tank, and the other outlet goes to the tool. I'd probably put the regulator on the compressor at or near max. safe operating psi, and a second on the tee where the air hose connects to. This would seperate the pressureised air from the hose air.
Maybe I'm wrong? Maybe I'm right. Am I?
1 - 8 of 8 Posts
