i have a JP performance gear set part #5991. it is adjustable from -8degrees to +8 degrees at two degree increments.i have it set at zero.my question is what would the best setting be for my engine.will changing it make it faster.
its a 1972 454cu truck motor with 781 heads.solid cam 594int 592ex. 850 demon with air gap,msd ignition,16derees initial and 37total timing and headers.3000stall.E.T is 12.3 in a 3650lbs truck shift a 6000rpm.
