1 - 20 of 24 Posts
Hi,
I'm starting my first engine rebuild and have made a few observations that I'd like some help on. Odometer shows 165K.
First: The cylinders still show cross hatch marks. Can this only mean a recent rebuild, meaning would hatch marks still be visible after that many miles?
Also, connecting rods are numbered. Can this be from factory, or done during the last rebuild.
Second: There is no noticeable ridge at the top of the bore. At least not one I can hook a finger nail on. Can I just re-hone them and call it good? I will have the bore checked at the machine shop and see.
Third: 2 push rods were bent. I'll buy all new push rods. When I removed the rockers, I did not keep them in order. Since I am buying all new push rods, can I put the old rockers back in any order, or do I now have to but new rockers?
Forth: All lifters move freely, what else could have caused the push rods to bend. Timing chain seems like it's loose, but I have no experience to compare that to. Timing gears are lined up. Valve springs seem good and valves are seated properly, no leak test done on them yet.
Thanks
Discussion Starter · #2 ·
You will need to measure the bores and see. Sometimes with chevy a quick ball hone and good rings will seat right up. Chevy nore ford number there rods as far as i know are they cast in numbers. Or stamped if stamped or scratched they are surely from a rebuild.
Check the valve trian you should be able to find the reason the push rods bent. I would not reuse the rockers if at all possible cheap roller rocker these days are 50-150 bucks. Worth the money since the rocker is a possible cause of the failure. Are all the studs in good shape no wear or bent broken studs?
Many things can cause the push rods to fail. They are pretty much the weak link. If they were not lined up right they could of moved sideways and bent just from leverage and the springs.
Numbers are stamped. The lifters moved up and down freely, but when I tried to remove them, I had to pound them out. I will go with new lifters, push rods , rockers, cam and valve springs. Replace valves and seats as necessary. No broken studs.
Anthing else?
Thanks
Discussion Starter · #3 · (Edited)
No sign of piston to valve contact. Ive not gotten to the heads yet. I will check them tomorrow. The springs seemed good when I hit them with a hammer to check rebound. Valves seem to sit properly against their seats, but I just gave it a cursary glance.
How do I insure oil passages are perfectly clean?
I will replace lifters, push rods, cam, valve springs, rockers, valve seals. I think, because of the cost, I'll repalce valves and seats as necessary. Anything else.
Thanks
Hi,
Thanks
first, you didn't mention what motor you are working on.
small block chev would not have numbers on the rods from the factory, a big block would though.
i wouldn't count on a crosshatch meaning anything. someone could have done a terrible job with rough stones and its still there, or it could mean little wear.
It's a Ford 460. My theory is that some one botched up the last rebuild and the engine did not run for long.
Other observation are:
cross threaded spark plug.
2 missing exhaust manifold bolts on the same port and 1 broken bolt on another
engine oil was nasty, maybe they did not replace during break-in
cracked timing chain cover
2 bent push rods
Plus whatever I can find out at the machine shop
So, it's looking like even if it was a recent rebuild, it did not go right and I will recheck and redo. Hopefully I won't screw it up also, this is my first.
Thanks
Banned
2 bent push rods
Thanks
don't think so.. the fact that the lifters had enough of a film that they needed to be pounded out.. says it was running a good long time..bent pustrods , mostlikely from floating the valves..
Discussion Starter · #8 ·
I see your point. I also saw incomplete combustion in another cylinder that did not have the bent rods. My guess is that this is also from bad valves.
Does that sound right?
Thanks for your help guys. I'm getting closer to getting it to a machine shop and getting the problems resolved. Again thank you for sticking with me.
The best thing to do is get the block checked out by a machine shop. This way you will know the cylinder size, if lifter bores are ok, clean block, they will take brushes and clean oil galleries. They will check your crank. You can look on back side of bearings to see if they are standard or .010 under. Rods need checked to see if they need resized. I would find another place to shop instead of Auto Zone. Check out this kit from Summit Racing with pistons included are priced better than the kit from Auto Zone. Federal Mogul Premium Engine Rebuild Kits MHP178-300 - SummitRacing.com. Like I said the block needs to checked to know what size pistons and rings, and bearings.
I'm not a fan of Autozone, But's it's the only store in town. I will go with Summit. The guy at the machine shop is trying to sell my his kit. I'll skip on that.
Thanks
You could talk to the machine shop guy and ask him what brand name parts his kit has. Print the Summit Racing kit and show him. Ask him if he can match the price, Sometimes they will work with you. Be sure to talk to him about the right pistons to use, flat top or dished to keep your compression at 9.0. He will have to cc the chambers of your heads. My machinist has been a friend of mine forever, we grew up together in the same neighborhood. He will tell me flat out he can't compete with Summit Racing or Jegs prices. He says buy the parts and bring them in he don't blame me.
Discussion Starter · #13 · (Edited)
Discussion Starter · #14 ·
Kit from Summit is the same as the one from Autozone, just half the price!!!
I also saw some name brand stuff in the ebay kit, but what really turned me off to it was the "DuraBond" Cam bearings. I don't know anything about them, but my general belief is that anything that starts with "Dura....."
Is anything but durable.
(just an opining, not based on any fact)
I looked up the DuraBond bearings and found them in the $15 to $20 range. That's with the seller's mark-up. Now do I really want something like that for cam bearings. If it was a sensor, or something like that, I might get it, but to have to pull and possibly rebuild the engine again is not worth it.
I suppose I could also see if he would replace parts with better quality stuff, but it's not worth the headache and the shop is about 30 miles from my house.
This is what I have for labor:
Clean Block= 95
Seat valves and new exhaust valves= 200
mill head= 50
polish crank= 35
bore block= 200
hang pistons= 45
remove 3 broken exhaust studs= 150
Plus other misc stuff which brings total shop cost to: about $850. Fair enough, in my opinion. Although it is the first time I'm doing this.
Discussion Starter · #15 ·
So, Looks like it's decided. I'm going .030 over. just getting the machine work done now. The shop will also supply new EX valves, seats and reseat all valves, as well as put in new seals. I'll finish assembly with my own kit.
Thanks guys.
Dura bond is a brand name for melling and seal power is a brand name for federal mogul. Actually they both make pretty good products. Its not junk. If its in the kit i say run it and dont look back.
Both of those companies do make multi versions of parts with different quaility. Look for the word replacement or performance. Replacement bearings or parts are oem min. Spec. Its ment for factory replacement. They also make a high quality bearing with a similar part number. Check the part numbers one letter diff can mean its a much more expensive parts.
Also bearings dont cost much. Its usally all mark up.
sealed power cam bearings are not full round bearings. they are the style that start out as flat pieces and are formed into a circle. i would not use that style of bearing in anything.
Discussion Starter · #20 ·
Right now, I'm trying to decide between these two kits.
Sealed power:
Sealed Power MKP6321A-000 - SummitRacing.com
Melling:
Ford 7.5L 1993-1997 Engine Rebuild Kit
Summit one is just a little less, but does not have a new cam, or lifters. I'd like to get a new cam, lifters, push rods and springs.
So really, it's only a matter of a couple of hundred dollars, which is not a big deal.
What are your thoughts on Melling VS Sealed power.
Thanks
1 - 20 of 24 Posts
