First off I'm new here so take it easy on me.I'm about to build my first SBC and need some advise
My block is a 350 which needs to be line bored due to it was missing the main caps when I got it.Also I am planning on having the block bored to 0.30 over.I've been told this is about the best over bore size on a 350.
Also I will be using 58cc heads that I picked up.I was told that the were great heads to run on a 350.They also have to bee worked.
I need to know what size cam to run.I don't want stock because I want to have a bit more than stock.Can I run a roller cam without having the valve train completly roller?
Timing chain vs. gear drive?Pros and cons from those of you have delt with both.
Flat top vs. Domed vs. Dished pistons?Pro and cons.
Also I'm curious to what the compression ratio will be in this motor.
Last on the carb.Elcetric or manual choke?I'm carb retarded.
Keep in mind I need this motor to run on pump gas.
Thanks for any advise you guys can give me.
