Looking for a little help, getting down to the last few things on my c4 Engine Swap.. and needless to say i am not putting the original Serpentine system back on the engine.
Looking at a all inclusive March system, will link a pic. My plan was to get a kit with optional AC, and get an aftermarket compressor (needs new anyway) and then it comes with an older style Saginaw power steering pump.
I don't have much experience with converting pulleys so curious if there are any obvious roadblocks. The C4 has a steering pump with external reservoir. are there any issues converting it to the pump that comes with system? I know the stock pump is good but would have to change pulley anyway so just figured i would replace etc.
The ac i may disconnect and have the new compressor and brackets to install after initial tune etc.
Thanks for any help!
the 'Duracell Project'
if you chose to go with the last picture and V-belts, you'll need to change the water pump
serpentine uses a reverse rotation pump, v-belt uses standard rotation
i checked out march pulleys as they were local to me, it would have cost me $2000 plus
i ended up using v-belts and made my own brackets, my brackets are a little industrial looking
38,000 miles with no v-belt related problems
Automotive fuel system Automotive tire Motor vehicle Yellow Automotive design
Hood Motor vehicle Car Yellow Automotive exterior
Vehicle Car Hood Automotive lighting Light
As mentioned by orge make sure you use the correct direction water pump, I swapped mine when I deleted the AC & air pump & reversed it. Also I put on a UD crank & alt, still got a UD thridgen water pump pulley that's not on yet, I'll need to shim a bit to make right.
A lot of C4 guys delete the air pump with a march bracket & adjustable rod(ebay has an entire kit that cost pretty much the same as those two these days).
If I ever finally go electric power steering pump, I may use some short pump style V belt pulleys since I have a better selection of those sizes.
There are 3 SBC V belt pulley types, long water pump, short water pump and corvette. I also have a C3 corvette that now has short style pulleys w/o the corvette tax.
Automotive fuel system Automotive tire Automotive design Motor vehicle Fuel tank
Thanks for the replies. Yeah the kit i am looking at comes with all of the pumps. It is around 800$ and has the water pump, power steering pump, alternator etc.. I figured the water pump was already the reverse style being existing serpentine.. but it comes with a new one anyway. I could also use an old style water pump and put a groove-side serpentine pulley on it and run exisitng power steering with adjustable driver side alternator bracket. I guess that may be more cost effective. But i don't mind spending the 800 and having a nice clean setup. It would have an older style power steering pump which i don't guess would cause any problems. I also am considering possibilities of elec water pump and/or power steering and then have a very simple setup.. possibly just crank/alternator.. would be kinda neat and different but redoing all of the electrical is next on the agenda. I went with Sniper EFI and got rid of all the tuned port and accessories etc.
I did a swap with a 96 LT1 and couldn't use the stock brackets. Alan Grove makes several conversions to adapt serpentine belts and is the simplest, least expensive option I could find. I ended up making my own brackets pretty much copying what he makes using 1/4" steel plate and 3/8" ID standoffs. Not as pretty as some of the polished billet systems available, but just as functional at a fraction of the cost.
