From the way i am reading this diagram if i apply air pressure to port 32 it should extend the servo and tighten band just like it does on port 25? Or am i reading it wrong. When i apply air a little hisses out #7 check ball port #28 servo pin does no move.
there is a hole in the pan rail area... put air pressure there, the servo pin should apply the band.
do this several times.
:cool:
did you install the sealing ring for 4th gear dry ? Any oil on the servo pin?
I never air check the 4th gear section of the 2-4 servo and I never have a 'no 4th gear' problem.
