Basic Problem: Installing a BBC motor in a 67 El Camino with SS hood. (This is well know to be a problem with hood clearance for aftermarket intakes
ain: ).
I am planning to use a Weiand Stealth intake (spec says carb pad height is 5.25") with a Street Avenger carb (the carb is dual feed, with an electric choke). Also I am using an HEI distributor, so clearance between the air cleaner and distributor must be considered. I have expectations that this motor will produce more than 500hp, if I don't choke it to death with a weeny little air cleaner.
Based on comparison with my friends 67 Chevelle SS, and my motor assembled with the Stealth intake and Avenger carb, I estimate that I have 2.25" of clearance from the carb AC base to the top of the air cleaner (wingnut).
I already have a 9" diameter K&N filter with the open top. The filter element is 2" tall, the open top is 5/8" tall, unfortunately the base adds 7/8" (net height is 3.5"). When this air cleaner is used it exceeds the clear height by 1 1/8". I have another 9" base, but it is still a bit too tall.
I've looked everywhere, I can find 14" air cleaners with a 2.25" drop base (and several others with drops between 3/4 to 1 1/4). Also I've found several offset bases used to clear the HEI distributor. To use a 14" air cleaner I would need both the drop and the offset.
I've checked other manifolds (even though I already have the Stealth), and found the Performer with a carb pad height of 4.85" and the Summit Stage 1 at 4.53", I ordered the Stage 1 but when it arrived I found it was very similar to the Stealth and the carb pad height was nearly 5.25". Also, I know that the Torker II is low profile, but I am convinced that it will kill the potential this motor has.
I've looked into a different hood, but an unfinished steel hood with a 2" cowl is nearly $500. I really need a good fix, taking a sawzall to my SS hood is not the answer :spank: (I know how much we like to cut on our cars :mwink: , but that is not what I want for this project).
The Question??? Does anyone have any good ideas on how to fit a decent air cleaner on top of this beast??
