Hi all, having a heck of a time trying to plumb in my radiator cooler onto my air compressor. I was hoping I could get some help here.
My compressor has a 1/2 hard copper pipe that connects from the head of the air tank (pipe OD is 5/8). It uses a 5/8 long compression fitting nut and ferrule to attach to the head and another to the tank. I am taking that off and installing a 1/2" flexible copper pipe (pipe has the same 5/8 OD) to a derale radiator cooler (#15300) that has AN-8 fittings.
I am trying to figure out the easiest and most cost effective way to connect to the AN fitting. If I use JIC fittings I would have to get a flaring tool. I am having a hard time trying to find something the converts an AN-8 fitting to something that would work with the 5/8 compression fitting. I think I would need to convert from AN-8 to AN-10 (since that is 5/8) and then AN-10 to 5/8 somehow?
The other end of the add-on soft pipe will go into an air dryer (1/2 npt) then into the tank.
Any sizing guru's care to comment? Thoughts? Ideas?
Photos are attached.
