My paint gun has these specs.........
* Required pressure: 50-70 PSI
* Average air consumption:
12 CFM @ 70 PSI
10 CFM @ 50 PSI
* Cup size: 1 qt.
* Air inlet: 1/4'' NPS
I'm having great difficulty finding an air-compresor with the minimum of 10 cfm. Is 10 cfm really neccesary for a good paint job or should I be concerned with the compressors's psi rating?
Hotrodders.com moderator
Compressor rating
CFM is what you need to be concerned with..air tools require a lot of volume to operate properly..Soo you need one that puts out quite a bit of air..
See this example:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=3848
That is one tha tis represenative of what would be good in your garage..Lots of suppliers have similar units..
Do a google search and you will find lots of people who would like to sell you one..
Good luck
OMT
If this is your only paint job ever, just go rent a usable compressor. Otherwise, buy a real one. It really is not difficult to find sutable compressors. Home Depot, Lowes, TSC, Harbor Freight, all that kind of store can accomodate your needs. Once you have a capable compressor, you will use it for other jobs as well. It will run impact wrenches, drills, sanders, polishers.
Start looking for a unit with about 5 running HP. You do NOT want direct drive or oil-less.
