Is it just me or do all the air ride controllers kinda suck.
Yea they control height pretty well but they seem very primitive and only slightly better than a bank of switches.
I have been looking at them for my 1929 Dodge project. It's bagged front and rear, it has a solid front axle and will have full fenders. It will be modern, but look period reminiscent. No digital gauges, tasteful chrome and be a car you can drive.
My problem with the controllers I see, unless I missed some is;
They have a zillion buttons,
They have a gaudy Vacuum fluorescent display.
They don't control height on the fly, only if you push the button ( or on startup).
They are very expensive.
So I'm thinking of making my own. ( I'm sure it will be even more expensive!)
*It will have one knob to set ride height.
*No display.
*Will use 4 corner height sensors, the normal rotary style
*Will adjust on the fly, quickly if a door is open or the car is in park, slowly if the car is moving.
*Compressor control
*Will have a USB connection to upload software updates, and to modify the tuning parameters used to set up the car.
Only ONE knob??
There is only one important ride height and that is the design height. The height where the suspension is designed to be. Any other height and you are sacrificing ride and stability. Therefore the height knob will have movable indicators showing different heights and one fixed indicator that is the design height.
There is no practical reason to be able to adjust each corner of the car individually and separately every time you want to change the height. One knob is all that is needed. Up, down. If you want to slam it and get all the air out, just turn it all the way down.
No display???
A Vacuum fluorescent display is great on, ...well nothing I can think of and certainly not on a 1929 Dodge. if you want to see pressures, add a pressure gauge. If you are shooting for a specific height, get a ruler and adjust the height sensors to be correct. The numbers on the displays don't mean anything anyway. Heights other than the design height will just be like "really low man" but still driveable, or "man that's one huge speed bump, crank up the bags!"
There will probably be a light that comes on to show the car is at the set height, or still trying.
Adjust on the fly???
It will continuously adjust the ride height whenever the ignition is on. There will be an input to the controller, usually connected to the door switch, that will tell the controller to update quickly. This will be nice when your 350lb buddy gets in and out of the car, it will automatically adjust. Once the doors are closed the load won't typically change except for gasoline usage so it will update very slowly. Except for what you toss that body in the ditch along the highway...
Compressor control???
It will control the compressor. this will eliminate the cost of a separate compressor switch and will allow the compressor to come on early if the controller sees it needs a lot of air, rather than waiting until the tank is low before turning on. So if you have it layed out and then hop in and start the car. The controller will see it's going to need a lot of air and start the compressor right away rather than waiting for the pressure to drop.
So, does everyone think I'm crazy?
Or does it sound interesting and you want to hear more?
Keith
The above statement is considered a public disclosure of the features described herein and are released into the public domain on the date of this post. No features described in this post may be patented, copyrighted subjected to DRM or otherwise access controlled in any manner by any party. All features and ideas in this disclosure and all related discussions are subject to the FreeBSD Documentation License.
*No display.
*Compressor control
Only ONE knob??
No display???
Keith
