I was almost finished with my brake lines on my 37 Ford Tudor. I had the master in under the frame. Bet my lines for the back, started going foward with two lines. Then it happened.. I have a Mustang II front end on it. My frame isn't boxed in the area where the brake hose should go. There were no connectors on the frame to hook the hose to. I bought both weld on, and screw on brake line clips. I found a hole that wasn't need close to the spot, so I inlarged it. The hose fit fine there, but the clip wouldn't work there. There are two frames, or sheetmetal over the frame. Anyways it won't clip. I then tried one of the clips that I bought from Speedway Motors. They won't work either.. The only other thing I found was a threw the frame connector. Trouble there is that it is 1 1/2" long. The way that would work is that I would have something that would stick out over an inch from the frame. Is there some other way of doing this?? Besides. I can't really see paying a extra $50. to hook up the front brakes.. Thanks.. Al
