1 - 9 of 9 Posts
I am changing which side my alternator mounts on and with the new mount I only have an inch clearance to the inner fender. It's a 350 in a 48 Chevy. Attached is a photo. Do you guys think it's enough clearance?
Thanks, JT
Photo is not very clear, blow it up and gets worse.
Try mounting the alternator a couple inches forward to clear valve cover. Add another belt loop to alternator. The pulley on the power steering (?) pulley does not have enough wrap.
might require a bit of fabrication………..
I'm not having any trouble with clearing the valve cover, the mount is as far in as it goes. As long as I'm ok for clearance to the fender it will be good. Thanks!
1 - 9 of 9 Posts
