Right on, Doc! 73, first thing to do: FULLY CHARGE THE BATTERY!!!
An alternator is a maintaining device, meant to keep the battery at max charge while various draws are working off of it. If you have a completely dead battery and you try to charge it with the alternator only, you will burn out the new alternator. Now be it internal or externally regulated, at the least this will usually burn out the regulator. Quite often it will melt the varnish coating on the stator wires and short out the stator. If, by luck, you alternator is still good, a quick and dirty test to see if it is charging is to touch a wrench, screwdriver, ect. to the back bearing cover. If the alternator is energized and putting out, there will be a reasonable magnetic field here. The harder the alternator is working, the stronger the field.
Check all elctrical connections.
- * Dirty battery posts can cause the battery not to charge, but the idiot light will go out.
* Next check all fusible links, even the ones to the starter.
* Make sure the stud in the back of the alternator is tight in the housing.
*Bypass the charge wire by using a booster cable from the alternator stud to the positive battery post.
*Slide a small screwdriver in the "D" shaped hole in the back of the alternator. If the alternator starts to work, regulator is bad. If, after all this doesnt work, try a new (fully charged) battery, and a new alternator.
