I have a 67 International. The wireing was so bad I cut every inch of it out. I will put a new wireing harness in it later but right I want to get it driveable. I wired in a new ignition switch and she starts right up. I have two questions:
1. It has a non stock alternator in it now but I'm not sure if it is a internal or external type. How do you tell the difference?
2. What would be the simplest way to wire in a 3 wire GM alternator and volt metter? I know the "Bat" terminal goes to the battery but what about the little plug marked "R" and "F"?
Thanks
Thanks
