I recently got a new angle finder from Speedway (their $9.95 special). After using if for a while (and actually setting my rear pinion angle with it) I discovered it might actually be giving false readings. But before I complain to customer service I just want to make sure I'm not making some sort of error in the way I'm using or reading the gauge.
The problem is I can place the angle finder horizontally on the rear frame crossmember, for example, and get a reading of zero degrees when the gauge face is pointing toward the rear of the vehicle. But if I turn the gauge 180 degree so the face is now pointing toward the from of the vehicle, and I put the finder in the exact same spot, I get a reading of 2 degrees of angle (a tilting of the frame from left to right).
My guess is the face of the gauge was not installed properly or not "dead centered" with the needle - or else the face somehow was damage during delivery. Anyhow, has another else had a similar problem and more importantly - a solution (short of returning the unit).
