I have an XE 268 in my car. I think it would work good in your truck. That would be the biggest (duration wise) I would go. You need at least that much duration to bleed down some of that compression anyway. Also, the comp cams XE line has pretty steep ramps for a flat tappet. Some guys have had excessive wear issues. I don't have any problems with mine, but it does "tick" a little. If you do get an XE, install a set of Crower Camsaver lifters. They should make it last.
BTW, the XE 268H has a nice lope at idle.
