my 68 cougar has a 302 " 74 engine " i just put it in over the winter. it is running EXTREAMELY " rich , when i do get it running it leaves black marks on the ground. today i checked oil was way over full , it had " GAS " in the oil.
when running you can almost watch the gas gauge go down.
this carb was given to me , i rebuilt it over the winter with the kit from holley. i then took it a freind who is good with carbs to go thru it and make sure it was right. he set the air / fuel screws and the only thing he found was just a bit of old gasket in a couple of internal passages.
should i just forget this carb and buy new ? iam very frustraded with it and don't want to ruinen the engine by spinning bearings.
