Yup new guy here. Yup made my introduction in the other forum already. So here's my issue...
I have a 55 Willys Wagon that idles at 190 degrees pretty much all day but when the RPMs get above 2k it will run 230+ regardless of vehicle speed. It will go from 230+ down to 190ish in about 45 seconds when the RPMs go back to idle. Casting numbers say it's a 1979 305. Other than an Edelbrock intake and carb it's stock. Radiator is a 4 row with a core about 16X24 and has been flushed and flow tested. Has a 190 T stat that is in correctly and functions(I've tried a different t stat with no effect no 1/8" hole drilled) I have also installed and electric fan as the mechanical fan sat too low to line up with the radiatorCenter line of fan is about 8" lower than the center of the radiator). I've tried 2 different water pumps and I think this is where I'm running into problems. Both have pushed hot coolant out of the block into the bottom of the radiator. The top radiator hose is cold and the bottom hose is hot. I have a short style water pump from a 63-67 Corvette that is supposed to be standard rotation. The pump looks identical to the pump show in post #6 of the "mild 355 overheating" thread. I run V belts and the pump spins CW. I even went so far as to fill the kitchen sink with water, hook an electric drill to the shaft and spin it CW. It drew water in through the lower raditaor hose port and pushed it out like it would push into the block. But when I put it on the engine the bottom hose gets hot and starts to fill the radiator with hot coolant as soon as the T stat opens.
Now I'm willing to admit I'm likely an idiot and this is an overly simple fix. So let the flaming and heckling begin. All I ask is that if you could possibly help me fix this issue while you have your fun please do. Thanks for the help...let the fun begin....
