I'm new here and came across some helpful tech info while researching gear installs. In my case, I'm setting up a new set of Ford Racing 3.31 gears (face-hobbed) along with a Strange spool and new bearings/cups.
My question is with the pattern difference between the drive and coast sides. My understanding is that if the patterns are on opposite sides of each other, this indicates the pinion depth needs to be increased to bring the pinion closer to the ring gear.
I didn't have the original pinion shim as a reference, so I used a 0.030 shim as a start with 0.008 backlash. I'm using a mockup pinion bearing (new) that I honed out to allow for easy removal/install when adjusting pinion depth.
This is the pattern I got with a 0.030 shim and 0.008 backlash:
DRIVE
COAST
The hard parting line across the top of the drive side makes me think I need to go deeper (maybe a .032 shim), but the opposing patterns between the drive and coast confuses me.
I then tried a 0.033 shim with 0.009 backlash and got this...
DRIVE
COAST
Meh, not any better. So, then I tried a 0.040 shim with 0.006 backlash to see what the gear pattern would be. Sure enough, it moved it deeper but the pattern looked a bit more "balanced" with the 0.006 backlash.
DRIVE
COAST
Went with 0.036 shim and 0.006 backlash and the pattern got better with the drive and coast patterns.
Should I try a 0.037 shim with the same backlash, or am I going in the wrong direction?
Thanks in advance!
DRIVE
COAST
DRIVE
COAST
DRIVE
COAST
Thanks in advance!
