I did some searching here and it looks like everybody is trying to plug or reroute the hoses. Sorry if it gets repeated.
I installed a Vintage Air a/c with a heater system, heater control valve and would like to keep the heater core (it does get somewhat cold in Bakersfield
. The plan is to replace my old 350 with an almost completed 383.
I bought an aluminum long style water pump from Powerhouse here and it has only one big outlet for coolant (lower inlet from the radiator). My old water pump had 2 lines.
Should I return the pump back and get the one with 2 lines? Or can I route one heater hose from the water outlet on the front passenger side of Edelbrock RPM intake and the return heater hose back to the intake inlet (by the t-stat) on the front as well? There are two 1/2" water holes there now. There is another 1/2" water hole on the back of the intake. Should I use that for a return hose?
Any suggestions?
Thanks!
Denis
'67 Camaro RS
Any suggestions?
Thanks!
Denis
'67 Camaro RS
