I'm trying to decide how to replace the goop the factory placed between the quarter panel skin and the inner structure in a couple of spots presumable to prevent flutter and vibration in the panel. It looks like they used regular seam sealer for the job. But that hardened over time and let go making it pretty much useless. I'm aware of the 3M flexible foam catridges, but I'd really rather not spend nearly $100 for a blob of foam the size of a quarter. Are they any alternatives? (The under side of the panels are painted with epoxy primer.)
Whatever the solution turns out to be needs to have sufficient working time to allow the panel to be positioned and secured. I'm tempted to use urethane flexible seam sealer. But I've seen reports that the urethane seam sealer and epoxy primer don't always get along.
Ideas?
Ideas?
