I'm putting new leaf springs and a rear end in my 1980 Trans Am. All the bolts under it have been seized up and I've had to break or cut all of them. Now I'm trying to cut out the rear leaf spring shackles. I managed to cut the lower bolts on both sides so I got the leafs to drop out, but the top bolt is still holding the shackles in. I had to cut through the old bushings to get to the bolt and cut it, and that was a huge pain.
I used a sawzall with a bi metal blade. It took probably a half hour per side. Now these upper ones will be even harder as they are really close to the trunk pan. So I've got a tiny space to cut them out. Breaking them with a breaker bar is probably out of the question, as one of the nuts is weathered down and I can't get a wrench on it.
So any tips to make cutting through a bushing and bolt in a tight space easier? I've gotta get these shackles out because they are worn out bad.
