Depending on your climate... anything that "congeals" would sure as heck freeze up solid at -20°C (around 0°F). :nono: I learned that an an early age on an old snowmobile .... yeeeehaaaaaaw! :thumbup:Rob Keller said:I will use WD-40 or similar product to penetrate & as a vehicle to get lube in there I would try to soak then in a synthetic oil so it will last longer
After soaking hang them up & let them drip out so after they are reinstalled they wont leak on your dash, feet & floor
White lithium grease's probably the best because it will go in ,in a liquid state & then congeal to a grease state.
Well I hope this helps!
Rob :thumbup:
jimfulco said:Might try some BreakFree CLP.
