1 - 6 of 6 Posts
After researching and getting helpful info from the board members here i think i have figure out what im going to use on my 327. Does anyone have a desktop dyno they could run this setup on. Thanks.
600cfm carb
performer intake
Well i guess im going to go with
600cfm carb
performer intake
comp XE256H cam
double hump heads 2.02
bored 30 over
attached to my powerglide w/3:08 gears
Thank for taking the time to do this for me. :thumbup:
When you have time can you run it again?
Cam:
Duration @ 0.006": 256° / 268° Duration @ 0.050": 212° / 218°
Max Lift w/ 1.5RR: .447" / .454" Lobe Separation: 110°
Lobe ID#'s: 5441 / 5230 Intake Centerline: 106°
edlebrock performer intake
1 5/8 headers
64cc heads 2.02 IN, 1.5 EX
327 engine bored 30 over
sunsetdart said:
I put this in our desk top dyno and without all your cam specs ,header size, more info on intake,exhaust valves.......conservatively 260 HP
after loading your specs, we came up with max HP @ 5000 RPM- 348hp- torque-366 ........at 5500 348hp, but torque falls to 332. At 6000 rpm...328 hp ..torque 287...6500rpm...302 hp, 244 torque. so you see after the peak at 5000 everything starts to fall off.
1 - 6 of 6 Posts
