Is that a good thing or a bad thing? Anyway to tell without opening it up?Could have straight cut planetary gears.
Good thing if you are after ultimate strength and durability.....bad thing if you want it quiet, straight cut gears tend to whine or howl/whistle.....sounds like a school bus in low gear. (LOL).Is that a good thing or a bad thing? Anyway to tell without opening it up?
Thanks. No, pan looks shallow.Good thing if you are after ultimate strength and durability.....bad thing if you want it quiet, straight cut gears tend to whine or howl/whistle.....sounds like a school bus in low gear. (LOL).
Other than finding someone who has a code list for the side tag I think the only way to know the innards is disassembly.
Does it have a deep pan on it?
The T-425 is a FWD transaxle... You may be thinking about a T-475 transmission which was used in many motorhome applications.Smokey you are correct 💯 my opinion was based on 1980 RV but this day in time who knows😅Ihave 425 in 1990 service truck
I once worked for athe city I lived in. They had a large truck ('brick truck") we used to build manholes with. It was new and this was in late 70s to early 80s IIRC That truck had a 4 spd (or was it a 5 spd? can't remember) automatic trans but I never knew what GM named it. It was a heavy duty auto trans too. Maybe this guy's trans is one of those??Smokey you are correct 💯 my opinion was based on 1980 RV but this day in time who knows😅Ihave 425 in 1990 service truck
TH400's are three speeds only. As stated, likely an Allison.I once worked for athe city I lived in. They had a large truck ('brick truck") we used to build manholes with. It was new and this was in late 70s to early 80s IIRC That truck had a 4 spd (or was it a 5 spd? can't remember) automatic trans but I never knew what GM named it. It was a heavy duty auto trans too. Maybe this guy's trans is one of those??
