1 - 1 of 1 Posts
Discussion Starter #1 (Edited by Moderator)
AOD Conversion Parts
I have converted my 67 Mustang to a manual transmission and have the following AOD conversion parts for sale...
1.) $90 - TCI aluminum extra capacity AOD or AODE transmission pan. TCI Part Number is 438000.
http://www.summitracing.com/parts/tci-438000
It is drilled and tapped for a temperature sensor and comes with...
1 unused gasket
1 slightly used gasket (in good condition)
13 stainless steel bolts and washers
1 steel bolt and washer (I lost one of the stainless ones)
1 pipe plug
1 used filter for reference
1 magnetic drain plug
2.) $300 - TCI Street Fighter Torque Convertor. Ford, 1980-93 AOD, 5.0L, 11.4" Bolt Circle - Part Number 832800. It has 200 miles on it and works just like it should. It comes with Drain plug and Flywheel Nuts
http://www.tciauto.com/tc/streetfighterr-converter-ford-1980-93-aod-5-0l-11-4-bolt-circlehtml/
5.) $40 -- Flex Plate, 164 tooth, 28 oz. imbalance. Little to no visible wear. This part is needed to put a Winsor block in front of an AOD.
6.) $80 - 67-68 Mustang AOD conversion cross member. Puchased from CJ Pony Parts - # TRA-670-640 . It does have some chipped paint from installation and removal, but is otherwise in excellent condition.
http://www.cjponyparts.com/california-pony-cars-transmission-crossmember-aod-tremec-1967-1970/p/T5C13/?utm_source=google&utm_medium=merchant&utm_campaign=shopping&gclid=COb4r4uH7sACFVJo7Aod0joA-g
7.) $60 - Lokar AOD kickdown kit Lokar # KD-2AODHT or PATC #89, and Carburator Bracketry PATC# 8LB (NO SPRINGS). It comes with home-made helper return spring that did not seem to be necessary with my setup, but was highly recommended by the forums. It also comes with the adjustment tool for setting the Throttle Valve Cable.
http://www.transmissioncenter.com/Lokar_Shift_Levers_TV_Cable_Shifters_Shift_Lever_Rod_Dipstick.htm
9.) $15 - TCI TV Cable Bracket Corrector Kit, TCI# 376715. This kit was bought by mistake. It is for adding a carburetor to a previously fuel injected late model 5.0 Ford, not a early model carburated Ford.
http://www.summitracing.com/parts/tci-376715?seid=srese1&gclid=COe3v-iL7sACFc1i7AodNwMAqw
12.) $70 -- 1330 series 28 spline Slip Yoke for the 4R70W Ford transmission. This fits the AOD that is advertised next because the AOD has a 4R70W tail housing for strength.
13.) $300 -- 1991 Ford AOD Transmission. I have put 2500 miles on this transmission, but could never get it to work properly. I am selling it cheap basically for the hard parts. It has lost overdrive three times in less than a year. I suspect that the case has a internal crack. Please contact me for the whole story. It has. . .
4R70W Tail Housing, this allows for a beefier slip yoke (ad above)
Rebuilt valve body with less than 100 miles on it
A Superior Servo
Dip Stick and tube
Stamped Steel Drum
Neutral Safety Pigtail
New Pump -- 2500 miles ago and recently disassembled and checked
Please note that I have a B&M Shift Kit that goes with this transmission and that the Valve Body
Plate has been drilled for this kit. It is also missing the shifter shaft.
Missing item numbers have been sold. It is best if you contact me through the CL ad here where all the pictures have been uploaded...
http://kansascity.craigslist.org/pts/4676172927.html
Please view my other 67 Mustang ads on CL by hitting the "more ads by this user " button. And, shipping can be arranged with a US Bank Money Order paid upfont, parts will be shipped as soon as money order is cleared.
Thanks,
Noel
Asking Price: Best Offer
Condition: Great
Location (City, State, Country): Sedalia, Mo. USA
1 - 1 of 1 Posts
