1 - 9 of 9 Posts
www.1965comet.net
How do I decode the following info that was on my tag
PKB A31
062070 F16
E4TP AAA
thanks
g
Troll Hunter
The E4TP would indicate it was probably from a truck. I'll look in my interchange book when I go out to the shop later.
Glad the Jeep is on the road
E4TP tells me 84 truck. 062070 is a serial number. PKB would have been the in plant build code.
One of the others should decode a build date but I forget which one.
All AODs were built at "Fort Livonia" at 36200 Plymouth Road in beautiful Livonia, Michigan.
www.1965comet.net
Discussion Starter #5
Thanks all....knowing it came out of a truck tells me this model should be strong....
g
Best guess based on what they built that year would be that it was from an 84 F150 behind a 302. Should be fine behind any small block.
AOD info
Yeah Im runnin a F-250 83 Exploder . Mine has C-6 but door sticker says it came with an AOD trans behind a 302 . The Exploder Being the Sport Utility 3/4 Ton Pick up . <<, If thats any help ? Sean
1 - 9 of 9 Posts
