Okay, I've searched all the discussions about 4 link vs. 4 bar vs. triangulated 4 link vs. wishbone vs. ladder bar and still have a question.
I'm in the process of going airbag on the back and realize there's some good stuff out there available but I still need to ask a question.
Is there anything inherently wrong with a ladder bar setup? In the old days, we ran coils mounted and ladderbars all the time with great results but I see that has become the least used technology these days. Assuming the ladderbars have adjustment to enable some limited fine tuning, what am I missing that makes them undesirable?
It'll be on a 41 Chevy Coupe, not looking to race it or drive it everyday or cross-country...... Thanks everybody.......John
ladder bar
Their is absolutely nothing wrong with a ladder bar setup, As for the 4 link setups they work best for drag cars, because they are more ajustable. Run your ladder bar, i personally have a 1998 Sonoma pro-Street car and expect it to run mid 10's with ladder bar setup.
Zipper
The main reason folks do not run ladder bars IMHO is they use up so much room under the car. A lot of them require floor modifications and do not leave a lot of room for the exhaust. I prefer the 4 bar set up myself. I have used about everything over the years ( except air bags ) and found the 4 bar set up to work the best for me ...
You can see my latest project ( with 4 bars on coils ) in my project journal.
Deuce ...
Member - AMC/Rambler "guru"
Ladders don't have to take up much room. I made a set for a mid powered car and mounted them like truck arms or slapper bars -- bolted right under the axle. Used 2"x1" 11 gauge tubing welded to the stock axle plate so I kept the shock mounts. Use shims from a 4x4 shop to set pinion angle. Since you've run ladders there's no need to go into any setup details! This is a more rigid setup than some ladders though, so will ride a bit rougher. I had no handling problems and the ride was pretty good as long as roads were relatively smooth. I used large rubber bushings in the front for some flexibility (from an 80s Caprice, front lower bar bushings) and a panhard rod.
Linkage suspension rides better and can handle better. That's the main reason for using it on a street/strip car. Ladders are cheap but work, ride suffers on a rough road. And as pointed out, you can adjust links much easier -- no shims!!
