1 - 20 of 25 Posts
· Registered
Pontiac 400 block
Performer RPM heads (http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2439&prmenbr=361)
Forged high compression pistons
performer RPM package (the 1.5k-6.5k rpm one http://www.jegs.com/cgi-bin/ncommer...626&prmenbr=361)
New crank (Not sure if we need a machine shop to balance it or what)
Forged rods, every major component forged, etc
No cats. High flowing exhaust, (probably Hooker)
Turbo 400 tranny.
Stock gears for the time being (2.73's i believe) it's a 78 Trans Am
Pictures/movies/descriptions of the project: Project
If you have any guesses of power output, i'd love to hear it. My friend and I are new to this and we want a general estimate. Please specify Crank/Wheel hp
· Glad To Be Here
No guess on your power output. Change those rear gears first. Anything you do to the engine will be a big disappointment if you keep those gears. For all around use go with something in the 3.5-1 ratio. For better performance go somewhat steeper; around 3.73-1 or up to 4.11-1.
· Pure American Muscle
If you want a good idea of what it will make you will have to provide us with better specs.
Such as:
The compression of those "high compression pistons"
Cam spec.
Rocker arm ratio
Carb size,
Type of ing.,
As for the heads I know there is a link but unlike me and maybe you some people have 56k Lol. Add the specs for the heads.
Valve sizes
CC size
Also
Heads size and length
ect... anything that could make a diff. in HP
Also any port jobs done to the heads. If you want good guesses we need good info. If this is all listed at your site sorry but im lazy. lol.
O and yes you will need to have your assembly balanced if you plan on running an engine making 500HP.
Chris
· Registered
arg.
Heads: Performer RPM Pontiac, 72cc, Complete, (each)
A 72cc chamber version for high compression, racing applications. Heads have Ram Air IV exhaust port flanges.
Detailed information on the heads can be found here (pretty 56k friendly)
http://www.edelbrock.com/automotive/headpont.html
"Power package": Kit includes matching manifold, carb, and cam & lifters.
camsaft/lifters specs:
Adv. Duration: 308°/320°
Duration @ .050'': 231°/240°
Gross Lift: .313''/.313''
Lobe Seps. 113.5°
Pistons: 400ci Stock-Type Piston, .030'' Overbore
Piston Dia.: 4.150''
Piston Top: -6.7cc Dish, 4-Valve Reliefs
Pressed Pin
Comp Ratio: 10.24:1 w/69cc Heads, 7.16:1 w/114cc Heads
Ring Grooves: 5/64'', 5/64'', 3/16''
(maybe they aren't high compression pistons after all.)
· Glad To Be Here
jayls5 said:
We plan on driving it on the street, not all out race.
This doesn't matter. When you upgrade any engine to performance type figures the HP and Torque curve go up in the RPM range. Without changing the rear gears you would have to run in first or second gear all the time around town in order to keep the engine in the performance RPM range. Even at freeway speeds (60-70) your RPM would be below the power range that the modified engine would run best at.
· Glad To Be Here
EXAMPLE:
2.73 rear gears with 26"diameter rear tires at 60 MPH would be approximately 2174 RPM. This is more than likely well below when the RPM cam begins to come into the power curve.
· Registered
Discussion Starter · #9 ·
So you guys suggest some different gears to mend the situation?
I thought power is still made below 1,500 rpm... it would just be very little. It would still drive with 2.73's for the time being until we replaced them right?
Suggestions for the best street gears? 3.73?
Thanks for the help guys.
· Premium Member
I think the reason you're not getting the answers you want is that your question is kind-of vague. You want a car that you can drive on the street and make power with is really all I know about this thing. Frisco is right, with any cam you're goign to need more gear. Shoot for a 2500 Stall. 200-215cc intake runners, 72cc chambers with the flat-tops is fine for iron, you could probably push the 64's with aluminum. I think you can do better than the RPM heads for 1700 dollars a pair (that 840 some odd dollar price is for EACH head).
You can run a big cam if you want, but you may have to up the stall. Push up your RPM range and now you're starting to talk about upgrading the springs, valvetrain, rods, oiling system, crankshaft, and things get really expensive past 450 horse/ 5500RPM.
K
· Registered
I copied this from Edelbrocks web sight........
422 HP in a 400 Pontiac
Edelbrock Performer RPM Power Package Components for 400 c.i.d. Pontiac:
Edelbrock Performer RPM intake manifold...............................#7156
Edelbrock Performer RPM camshaft kit.............................. ...#7157
Edelbrock Performer Series carburetor (750 cfm, manual choke).........#1407
Edelbrock Performer RPM Pontiac Heads (72cc)..........................#6059
Edelbrock timing set..................................................#7812
Edelbrock valve springs
(included with heads; stock heads use #5757) .........................#5767
Edelbrock retainers (included with heads; stock heads use #9735)......#9736
Edelbrock valve locks (included with heads)...........................#9611
Shortblock Components:
Bore.........................................................4.120" + .030"
Stroke.......................................................3.750" (stock)
Crankshaft...............................................cast (shot peened)
Rods....................factory steel (polished & shot peened-A.R.P. bolts)
Pistons..................................................TRW #L2262F + .030
Rings..Speed-Pro #R9228 + .035 Moly Top-Cast Second (5/64" x 5/64" x 3/16")
Head Gaskets.........................Fel-Pro printoseal w/steel wire #1016
Test Engine Specs:
Main Bearings (clearance)..............Michigan 77 MS 496P (.003" - .0035")
Rod Bearings (clearance)..............Michigan 77 CB 758P (.0025" - .0030")
Piston Wall clearance................................................ .006"
Ring End Gap clearance...................Top ring .018" / Second ring .014"
Rod Side clearance .......................................... .015" - .018"
Compression ratio.....................................................9.6:1
Ignition and timing..............................36° @ 3000 RPM + MSD 6A box
Headers.................1-3/4" primary, 30 long with 3" collector, 12" long
Edelbrock Performer RPM Aluminum Cylinder Head Information:
Intake port volume....................................................215cc
Intake valve size.....................................................2.11"
Exhaust port volume...................................................175cc
Exhaust valve size....................................................1.66"
Combustion chamber size................................................72cc
Rocker arms............................................1.5:1 Roller rockers
Valve Seats cut at.....................................................45°
Material spec........................356 aluminum heat treated to T-6 spec
422HP at 5500, and 441 lb/ft at 4500
According to the graph, the motor is making 380lb/ft at 2500 rpm.
if this is an all street ride, that is WAY too much cam.
380 lb/ft at 2500. Peak torque, 441 lb/ft at 4500 and peak power at 5500? Seems to be a very good choice for a street driven 400 Pontiac to me..........
I also don't think your gears will be that big of an issue, in a street driven car. Dan
· Premium Member
I am going to disagree with ohio-dan about the gears. Even on a street driven car you wont get the full benefit of having that sort of power without lowering those gears. 2.7 gears are pretty tall. Id suggest 3.52 if your worried about its RPM range while highway driving. It will still give you a decent launch with the right stall.
1 - 20 of 25 Posts
