OK, guys, I'm really new to welding etc, but thing is .. after having my car waiting since spring 2001 I now finally have the chance to work on it.
I have a few questions about welding. I'm on a really tight budget *lol* Uncle Sam aint paying us that much *lol*.
I guess I have two choices .. a cheap MIG welder .. or a cheap ARC welder (stick welder .. correct ?).
What I need to do is the following:
1) Chassis work, may have to fabricate something for another rear end, or for coilovers if I decide to go that way.
2) Sheet metal work, since I don't believe in making wider rear fenders by adding tons of fiberglass and attach it with screws or adhesive to the body.
3) Roll cage ... chassis/body strengthening .. in order to stiffen things up and also reduce body flex (got problems just behind the top with metal cracking due to body flex).
Can I use an ARC welder .. a real cheap one hmmm say .. what amperage... 80 amp .. good enough ? Or should I go for 140 amp ? .. Talking about a stick welder .. .since having problems finding real real cheap MIG welders .. plus I want to be able to not only spot weld but to make real real strong beads when doing chassis and cage work.
I know stick is usually not good for sheet metal .. but I've seen attachments out there .. nowadays.. where one can supposedly weld 22 gauge metal.
Any thoughts ?
Any thoughts ?
