I recently purchased a magna flux dye penetration crack detection kit. Now im off to find more uses for it other than just checking heads for cracks. Are there any areas besides around bolt holes and coolant passages on engine blocks that should be checked for cracks? If you want to post a picture with a circled or highlighted area that would be very helpful. Thanks
Often by paying close attention to what the engine and components look like at disassembly will hint at possible cracks or blown head gaskets. If coolant is getting in the combustion chamber, it will look very clean compared to the adjacent cylinders from the steam cleaning effect. If the gaskets look good, cracks in castings would be the next suspect.
Cylinder heads can crack from the seat into the chamber, from bolt holes to coolant passages, guides can crack although this isn't too common at least in my experience. The chambers can crack between each other, especially the center cylinders where the crossover causes high or uneven heating.
Shown below are several images of magnetic test showing a cracks. These same cracks will also show up using dye penetrant inspection. Bolt holes to cylinders and/or coolant passages are good places to look on blocks. The starter bolt area of a Chevy block is another place that can be inspected for cracks. The starter nose is yet another.
Crack probably from freezing:
Below is a flat head block showing various cracks. A SBC can crack in similar places, especially from the steam holes of a 400 block:
Here's a diesel block, crack at red arrow, probably another at blue arrow. Webbing of a SBC can be cracked in similar places:
An article from Engine Builder mag:
Looking For Leakers. There are others I'm sure.
