ARGHHH!!!! No Spark!
Okay, here's the deal.. I finally got the engine and trans back in my truck last weekend and proceeded to hook everything up over the course of the week. Yesterday was the do or die time to start her up and well obviously I need some assistance in the wiring deptartment.
Yesterday I turned the key on and the engine was turning over but not starting. It was spitting smoke and yes even a 2 foot fireball out of the carb.
I have a eledbrock 600 cfm carb. Points type dizzy and a new accel coil.
The first thing I did was assume it's not in time so I turned the engine manually with a wrench on the altenator bolt until the grove on the crank was at 12 oclock. I then took the dizzy cap off and yes the rotor was pointing at number 1 cylinder. I then proceeded to double check to see if the spark plug wires are going to the correct cylinders, and they are. Lastly I check to see how I wired the coil (since this was the ONLY thing I forgot to log during my engine pull).. Here's how I have the coil hooked up.
There is a blue wire coming from the fuse box on the driverside of the truck connecting to the postive side of the coil. There is a small cylinder type thing hook on the coil bracket and that wire is also going to the possitive side to the coil. There is a yellow wire and the wire from the dizzy going to the negative side to the coil. The yellow wire is coming from a (junction??) on the firewall.
After I attempted to start the truck and got the spitting and sputtering shooting out of the carb I proceeded to reverse the wiring on the coil.(since I rulled out the timing issue), This did nothing at all...but produce a very small amount of smoke coming from under the dizzy cab... oops...
I'm sorry for the long post but I wanted to give as much info and be detailed as possible, thanks for any and all sugestions, please note that I"m a newbie and retarted as heck when It comes to auto wiring... :embarrass
