I am having ignition troubles for a 73 Vette. I have replaced the points with a Crane Cams XR-i module. Currently, the engine turns over strongly but I am not getting any spark. Further, I am getting only 9V at the starter and at the coil when turning the key to start, and a full 12V when the key is in the run position. The ignition switch is brand new and seems to be operating correctly. Finally, I know the XR-i module works because I can start the engine just fine when using a 12V spliced lead to the coil and one to the starter. Am I missing something fundamental here?
Thanks for any help you can give.
