I changed the ambient light sensor($14) and it didn't fix it. I notice that the DRL and gauge cluster lights don't come on auto. anymore. They only work if I turn them on manually. The stereo and OHC display turn on and off. They'll be on for a while and then go off for a while. They come on and stay on when I turn them on manually by the headlight switch. They come on when the DRL and dash come on when I turn the switch to the parking lights position. The headlights seem fine. They come on auto. with no problem. They don't come on when the E brake is on whick is normal.
I recently installed a OHC with van. mirrors and rear view auto. dim mirror and a code alarm remote start/ security system with carlink. Also, fog lights that I had hooked into a relay off of the headlights, but I recently removed them from a relayed circuit straight to a aux. switch
Could it be one of them things causing the problem or is there a switch or relay that is bad, BCM maybe?
