Is the needle position at 5 o'clock the max temperature on the scale?? If it is, the wire from the sending unit to the gauge has become grounded(shorted to ground) or the sending unit has gone bad causing the max scale reading.
These electric gauges are just simple resistance reading gauges. The less resistance to power passing through them, the higher they read. The sending unit is a temperature variable resistor, allowing no power to pass through when cold(zero or not yet in range on gauge face) and gradually allowing more ground (reading on gauge face) as they heat up, shorted completely to ground gives an maxed out reading. It won't return to zero as the needle freezes when power is removed, and is still fully grounded when you return power to it.
