found my problem for bent push rod put everything together tryed started it to day but the only thing its doing is backfireing thru carb got motor to tdc on comp dist is 180 off will change that anybody have more ideas ? thanks to everyone on last post info Ted [email protected] please write
ted 46,
With a bent push rod comes the thought of a bent valve. If setting the distrubutor 180 back does not fix the backfire then do a compression check to see if a valve is stuck open.
Sorry
Scholman
push rod
scholman said:
ted 46,
Sorry
Scholman
Doc here:pimp:
My thoughts EXACTLY...Don't consider it a fix until you find out what bent the push rod....
Push rods don't normally bend or dement on their own...
A stuck open valve would give you both a backfire and bend a push rod...
If your timing is on, Go to the valve that had the bent rod...use a sledge hammer handle
(not the anvil end...unless your REALLY p*ssed off at it...)
and work the valve up and down...Does it travel freely and not hang?
If not, Think Valve job.....
Even if it does travel free, do the compression test, It may be demented or burned at the end of the travel leaving it slightly open...
Doc :pimp:
