Last Friday night a group of us were cruising our muscle cars around town.
Towards the end of our cruising a buddy in his 68 Camaro (383ci) jumped on it and took off a bit. It sounded and looked great. I wanted to return the favor so when I was next to him (we were doing about 40mph) I dropped it into second gave it a little gas, let out the clutch and punched it to play a little 502.
Man was it a show. There were fireballs going everywhere. A buddy behind me thought I had installed flame throwers. I saw a couple flashes thru the cowl hood also.
To say the least, that wasn't my intent. My car typically runs very well.
The engine didn't rev at all. Now, if I give it a little more pedal while under load, the fireballs return. I have to give it a lot of gas and keep the rpm's above 1500 or idleing. To say the least, the 5 mile trip home was fast.
Now, when not in gear, if I give it just a bit more throttle than idle it just goes silent and dies. If I give it about 3/8s throttle, off idle, the engine sputters but jumps to about 1500 rpm and after about a second jumps to about 3K (with no extra pedal). Also, it is idling at about 400 instead of the normal 600-650 when warm.
I was thinking spark scatter so I replaced the 10 year old (20K mile) cap and rotor which were a little dirty inside and had some buildup on the contacts. I also replaced the plugs b/c I had been wanting to check them out anyway.
This didn't help the issue at all. I'm going to rebuild the 750 Holley HP DP tomorrow and pull the distributor to check the gear. I just added the HP main body last summer and installed an MSD ignition module at the same time.
I was planning on going to the track this Friday night, running slicks for the fist time, since it's the last test and tune of the season. Maybe it's a sign.
Any other ideas? I'm also considering the magnetic pickup or a more involved repair such as the timing chain jumping a tooth.
Also, the engine is not happy at any constant rpm. The rpms have to be increasing or it will die (other than at the 400 rpm idle which sounds like it wants to die).
Sorry for the long read.
