hello
i have a 350 CHEVY ENGINE
i did a replacment manifold and carb
i discovered then the engine didn't have a thermosta ? i was wondering before why the engine never went up in temperature...well now i know
( it's a projet car never ,drove yet with it )
i put in place a new thermostat ( spring domn to manifold)
now the engine want to overheat....!!!!
no coolant in engine oil , i checked
my coolant in radiator is very clean ( the coolant is 50 50 green )
i did a compression test at the radiator cap , everything ok
no leak ,nothing
i turn the engine on ,with the radiator cap off
after a minutes the water want split out
but i didn't see the water going up and down
the water pump is bad ?
or the radiator is clogged ?
it's a 1971 chevelle
thanks
no leak ,nothing
thanks
