I have a 97 7500 series truck that im taking the WEAK 366 out of and replacing w a 427 tall deck (which are both truck motors). The 427 i bought was an earlier model 2pc rear main seal block. Casting no 3999294 (68-84 model). The balancers are different b/c of yr models, so im wandering what the correct flywheel is i should use?
Ive noticed These med duty trucks had 2 types of flywheels (depending on eng size & yr models). One flywheel has a couterwieght and one does not. Wanting to know which one is correct for each eng? And the ealier model blocks dont have the same plug location for knock sensor on side of block that the newer tbi blocks have. But there is a plug hole a little lower down near oul pan. Does that location matter? Can anyone help me?
Need this trk back on the road…
